Ciekawe ogłoszenia
Re: Ciekawe ogłoszenia
Postprzez mcgiver » 27 cze 2020, 23:56
Jake napisał(a):Zeby u nas były takie ogloszenia i auta w tym stanie za takie pieniadze....
https://www.planetisuzoo.com/viewtopic.php?f=2&t=138169
wtf :roll:
nie widzę ani ogłoszenia , ani przejrzystości ... a co dopiero auta w jakimś stanie ...coś Ci się porąbało w ten piękny sobotni wieczór :lol:
Postprzez Jake » 28 cze 2020, 00:36
wtf :roll:
Moj drogi nie wiem jak Twoje dzisiejsze porąbanie, ale ja czuje sie dosc trzezwo i przytomnie :lol:
Link prowadzi do forum Isuzu. Bez logowania faktycznie nie widac zdjec, ale poza tym cała tresc powinna być dostepna. Nie bardzo wiem co masz na mysli mowiac ze nie widzisz przejrzystosci i czy widzenie przezroczystego jest juz elementem metafizyki czy filozofii. :)21
Jak cos Ci nie bangla mimo to to wklejam niżej cytat:
1996 Isuzu Trooper plus extras $1200
The day has finally come I’m selling my Trooper. Finally got it back on the road and then I inherited my wife’s Mini Cooper. So it’s basically been sitting for the last 3 months or so.
The engine is new and has somewhere in the 2500-3000 miles on it. It has been bored 1mm oversized to make it a 3.3L. The SOHC heads were swapped out for a set of DOHC heads. There is no check engine light and the engine runs great with plenty of power. The injectors were also updated with units for a 98+ Trooper. The exhaust is 2” from the manifolds to high flow cats and merges to a 2.5” high flow muffler. It sounds pretty good and is a lot quieter then I remembered. It will pass a North Carolina emissions inspection and if needed will be done at time of purchase.
At the same time the new engine went in so did a new radiator, hoses and all fluids/filters were replaced. Brake pads/rotors front and rear were replaced less then 1000 miles before the original engine gave out. The transmission was also replaced right before the engine gave out and has around 130,000 miles on it. The front 4wd flanges were upgraded to OE manual locking hubs and the electronic VSV’s were replaced with a manual valve. I’ve had zero problems since the swap. Stock drive flanges will be included if you’d like to swap back.
The exterior has dings and scrapes like any vehicle that has seen time off road. Tires are Cooper AT3’s with about 50% tread lift left. I balanced the tires about a week ago at work. An alignment was performed at Firestone about 6 weeks ago. Interior cloth seats were replaced with leather seats shortly after I purchased it. The driver seat has quite a bit of wear from getting in and out. Both front armrests show a lot of wear as well. The rear seat looks almost new.
So extras.....I’m also including the Service manual, Fuel/Emission manual and Electronic troubleshooting manual. I have a box that has replacement switches for the dash. I’m fairly certain I have a couple good ECU’s that can go with the truck as well. A second of OE manual hubs will also be included. One is good but the other needs a bearing.
Najpięniejsza jest cena - $1200. Z tym, ze oczywiscie nalezy moj wpis potraktowac jako wzdychanie do ksiezyca, bo auto jest po drugiej stronie wielkiej wody, a koszta sciagniecia go nie maja zadnego sensu.
Postprzez mcgiver » 28 cze 2020, 12:04
no własnie , zakładałem że ogłoszenie jest widoczne dla każdego, srednio mi pasuje zakładanie konta gdziekolwiek trzeba coś zobaczyć :roll:
nie wszystko rozumiem ale widzę że silnik ma nadwymiarowe tłoki co dało wiekszą pojemność wieksze wtryski i wydech , zmiana głowic z sohc na dohc , szkoda że nie ma fotek z pod maski
Jake napisał(a):Moj drogi nie wiem jak Twoje dzisiejsze porąbanie, ale ja czuje sie dosc trzezwo i przytomnie :lol:
no to żałuj nie wiesz jakie to fajne :)21
Postprzez Jake » 28 cze 2020, 16:41
Tak, silnik to teraz 3.3 DOHC :) I ogolnie fajny stan i duzo mechaniki poogarniane, a cena jak za Corse.
Postprzez Michał4x4 » 03 lip 2020, 23:34
Jake a tego widziałeś?
https://www.otomoto.pl/oferta/opel-mont ... c8299b2d44
Zakładam, że pewnie tak.
:)21
Michał4x4
Postprzez Jake » 04 lip 2020, 00:41
Michał4x4 napisał(a):Jake a tego widziałeś?
:)21
A dziekuje, widzialem, widziałem. On wisi juz jakieś 3 miesiące. Jest drogi i wcale nie taki wspaniały. Gdzies 2 tygodnie temu pojawił sie tez zielony, ale ładniejszy, z LPG i z poduszkami powietrznymi za połowe tej ceny. Był w naprawde ładnym stanie. Ja niestety przez wspaniałą chujnie koronawirusowa i zakup toyoty jestem finansowo spłukany wiec obszedłem sie smakiem. Oczywiscie sprzedał sie w dwa dni, co nie dziwi :cry:
Postprzez Quentil » 04 lip 2020, 02:40
Postprzez mcgiver » 04 lip 2020, 03:18
staro deskowiec zgnilec ramowy to chyba nie w guście Jake'a :)21 ...jak sądzę
Postprzez Quentil » 04 lip 2020, 03:32
Zdecydowanie nie w Jego guście, ale jak to mówili Rzymianie ze starożytnych Chin: Na bezrybiu i rak ryba...
:)21
Postprzez Jake » 04 lip 2020, 22:20
No paskudny xD A ta rama to sie chyba zaraz złamie :)21
Postprzez Legend » 14 lip 2020, 16:59
https://www.otomoto.pl/oferta/isuzu-tro ... Dd1Bh.html?
jest 14.07 i ogłoszenie chyba dopiero co sie pojawiło z ceną 36.900 ;-)))) ktos tu ma poczucie humoru :DF
Postprzez Quentil » 14 lip 2020, 18:07
Się z rodzajem paliwa trochę rozminęli :)21
Postprzez Jake » 03 sie 2020, 01:51
Czarne 3.2 przejsciowka w rozsadnej cenie:
https://sprzedajemy.pl/opel-monterey-is ... nr62209046
Postprzez Michał4x4 » 06 sie 2020, 20:27
Legend napisał(a):https://www.otomoto.pl/oferta/isuzu-trooper-3-5d-automat-200km-4x4-monterey-ID6Dd1Bh.html?
Już jest 31900
:)21
Michał4x4
Postprzez Jake » 06 sie 2020, 20:49
Nadal zabawne.
Postprzez AlekS » 06 sie 2020, 21:32
Hej, odkąd mam RSa myślę o wymianie na LTD. Co myślicie o tym modelu?
https://www.olx.pl/oferta/opel-monterey-CID5-IDG0KHj.html
Opel Monterey RS, 3.1 TD '93
AlekS
Postprzez Quentil » 06 sie 2020, 21:58
Zadbany szwajcar, jakieś 20k maks moim zdaniem i jeszcze do delikatniej negocjacji. A żeby nie było za kolorowo to chyba ciut oleju bierze bo odczyt węglowodorów rośnie we wpisach w książce, ale ja się tylko droczę :)21
Za to w proponowanych ogłoszeniach znalazłem VXa https://www.otomoto.pl/oferta/isuzu-isuzu-vcros-2001r-godny-polecenia-ID6D9wYL.html całkiem tanio jak na polski rynek. Ogłoszenie trochę dziwne, takie bez żadnego opisu :roll: Możliwe, że świeżo sprowadzony.
Za to ten 3.1 wygląda całkiem ładnie. Przebieg słuszny ale przy ponad dwóch dekadach eksploatacji po prostu prawdziwy jak na diesla. Chyba, że licznik drugie okrążenie już robi :)21
Niech doprecyzują co to stan wyjątkowy podwozia i ramy :roll: , najlepiej niech przyślą Ci zdjęcia. Jest nadzieja, że terenu nie widział i było dbane o auto.
Postprzez Jake » 06 sie 2020, 22:06
AlekS napisał(a):Hej, odkąd mam RSa myślę o wymianie na LTD. Co myślicie o tym modelu?
Fajny, widzialem to ogloszenie - wyglada bardzo dobrze. Pytanie czy w picowany pod sprzedaz czy faktycznie taki dobry.
Postprzez Legend » 07 sie 2020, 10:26
zdaje się, że ten LTD z Dąbrowy już poszedł, ja mojego LTD sprzedałem w sumie w 3 dni. i to było w lipcu tego roku.
Tak jak ktoś pisał - realna cena tego 3,5 to wg 16-17kpl jak po drodze się nie okaże, że na dzień dobry pakiet startowy 5 koła - ale jeśli serwisowany do końca i rzetelnie to może niekoniecznie.
Postprzez AlekS » 07 sie 2020, 11:06
No rzeczywiście ogłoszenia już nie ma...
Chyba przestanę oglądać ogłoszenia, bo się wkurzam jak widzę, że dałem niewiele mniej a nie mam klimy i jeszcze sporo dupereli do zrobienia bo poprzedni właściciel traktował jako woła roboczego i w ogóle nie dbał o to jak to wygląda...
AlekS
Postprzez Jake » 07 sie 2020, 12:13
No niestety tak to jest. Z drugiej strony czasami mozna kupic slicznego z pelnym wyposazenim ktory ma zezarta rame albo jest spawany z czterech po zdrzeniu z czołgiem. Zawsze mozna trafic lepiej i mozna trafic gorzej.
Postprzez Legend » 07 sie 2020, 17:43
miałem okazję rzucić na to autem okiem
https://www.olx.pl/oferta/opel-monterey ... 7d37d97f6f
totalna korozja tylnych nadkoli - przez nadkole wyciągnąć się dało elementy zestawu podnośnika, zgnite przewody pod autem, rama punktowo słaba ale zaś np przy przednich nadkolach miała fabryczną farbę bez nalotu - dziwne. Silnik świezo umyty podobnie jak i całe auto więc ewentualne ślady zatarte, gość twierdził, że czasem silnik gaśnie i nie ma mocy...coś kombinował ale ogólnie odpuścił, wnętrzne brudne, kierownica styrana jak przy 300 tys. Sprzedawca z tego ogoszenia zabrał z auta fajne oryginalne felgi z ładnymi oponami goodridge o plastikowy kondom na tylne koło ;-)
Postprzez Legend » 07 sie 2020, 17:59
aa zapomniałem dodać, ze oglądałem go pod Tarnowskimi Górami, był wystawiony za 6700 a gość chciał pisać kwity już za 5 :D
Postprzez Michał4x4 » 07 sie 2020, 20:00
Quentil napisał(a):Za to w proponowanych ogłoszeniach znalazłem VXa https://www.otomoto.pl/oferta/isuzu-isuzu-vcros-2001r-godny-polecenia-ID6D9wYL.html całkiem tanio jak na polski rynek. Ogłoszenie trochę dziwne, takie bez żadnego opisu :roll: Możliwe, że świeżo sprowadzony.
Biorąc pod uwagę, że tak wcześniej wyglądało i jest pewnie do opłat (tak zakładam) to nie wiem czy to taka okazja
Michał4x4
Postprzez Quentil » 07 sie 2020, 21:16
Bardzo ładna sztuka :twisted: :)21
Powrót do Pozostałe
