wodnicki112 napisał(a):co do spawów to jeszcze kolego musisz sie w tym podszkolic;p
marcinoski napisał(a):...
jak rama może nie mieć profili zamkniętych ?![]()
BUNNY_PL napisał(a):But good news - bumpers and all kind of plastics are finally finished !.
Original wiper arm is painted with some ridiculous spray paint - or whatever it is. I have sanded it down , primed with epoxy primer and than it was painted with black base + clear coat. Now it won't peel off ! and looks great in sunlight![]()
Working on bumpers was a real pain for me. Front bumper was broken and welded, then a lot of body filler was applied. Photos are not showing real life result. I will take car out and take photos .. soon.
As You can see here i have changed my rear bumper. There will be no bumper lights any more and blanking holes was more expensive than used bumper... I bought some used from import versions and repainted it ..
As You can see its close to some final result. I have to put bumpers on, finish this &^$% rear lights and put interior back inside. I will have to do something with scratched interior panels. I still don't know how to do itbut i will figure something out
BUNNY_PL napisał(a):I don't even know where to start. Car is finished in 95 % - just few interior bits and few minor things all around the car.
Lets finish bumpers maybe.
All metal bumper mounting parts were sandblasted.
Everything is covered in anti rust wax
I sealed all holes around fog-lights to prevent moisture and in result - rust.
I was very lucky to find this brand new rear bumper mountsfor silly money. Its also sealed as it should be !
Now lets move inside. I knew that something was wrong with this floor part almost 2 years ago when i removed all interior. Guess what, i was right. Between 2 steal sheets i found some my worst enemy - rust. So i cut one sheet out, welded another to the floor and sealed everything correctly . It happens on both sides of the car. On driver side it was not that bad.
Then i moved more to the rear of the car. I cleaned all small rust spots on the floor and then i applied some rubber coating .
Then i ripped out all old stinking floor mats and replaced it with new foam type ones.
old one
new one.
Then it was time for rims refurbishing. After painting it looks like new.
and my old wheel nuts covered with new chrome
I promised myself that i will take photos after everything will be finished but for now i will show You how it looks right now. On the roof You can find dust collected for 2 years. After final polish i will post some better photos. Lets say it just some place holders
Now im trying to finish interior and some small bits around the car. I think im very close to the end. Car made 240 km !!! since rebuild
. I will keep You updated.
